1 - 20 of 165 Posts
Edit: Kingston has in fact confirmed switching over to asynchronous NAND. Through people posting benchmarks on various sites I have gathered that the synchronous part numbers are v505A, v505B, v505C, v507, and v520. Likewise, the asynchronous versions are v506 and v521. Kingston's official response can be found here: http://media.kingston.com/support/downloads/V300_Benchmark_Brief_MKF_586.pdf
Edit 2: I've seen some benchmarks that make it look like there are v521/v506 that were shipping with synchronous NAND so the part # convention might be out the window. Their new v526 also doesn't seem to have a convention for the type of flash used. Looks like they are just shipping out whatever they can get there hands on for cheap.
As many of you probably know, the Kingston V300 is regularly one of the cheapest SSDs you can buy. The 120GB version is currently on Amazon, Newegg, and Tiger Direct for $70. For the last 6 months or so it has regularly been the cheapest Sandforce based drive with synchronous flash. However, with their latest revision of the drive there have been numerous accounts of people getting much lower benchmark scores than they should and they are all version 506. Here are a few examples:
http://www.overclock.net/t/1380526/kingston-v300-help
http://www.tomshardware.com/answers/id-1762558/kingston-ssdnow-v300-low-read-performance.html
http://forums.anandtech.com/showthread.php?p=35676298
Many Newegg Reviews:
http://www.newegg.com/Product/Product.aspx?Item=20-721-107&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
Most people think that it is the firmware causing this and others think that its the location of the drive's production(Taiwan vs China). If you look over the other threads you'll see people are experiencing the problem on drives from both countries though. As for the firmware I'm confident that's not what is causing the slower speeds. Sandforce is very strict with the extent that SSD manufacturers can alter their controller's firmware. They can't really do that much, hence why all Sandforce drives perform comparably if they use the same type of NAND.
I'm led to believe that Kingston has changed the type of NAND in the V300 v506 to asynchronous flash...Which is a huge deal. The benchmarks that people are showing on v506 drives match up to what other asynchronous Sandforce drives perform at.
The most compelling evidence is from what Kingston itself said:
Hello, I'm Jewel with Kingston Technical Support and would like to offer some clarification. Our V300 Solid State Drive uses the LSI SandForce 2281 SATA 6GB/s controller and MLC NAND from various manufacturers. The performance target for these drives is 450MB/s Read and Write using ATTO 2.41 with the SSD connected to a SATA 3.0 / 6Gb port. The SandForce 2281 controllers also employ a feature called DuraWrite™. In simple terms, this enables data compression and minimizes the data written to the SSD. DuraWrite™ extends the drives endurance and overall drive life with a byproduct of increased performance.
There are a number of benchmark utilities publicly available that you can use however Kingston uses ATTO 2.41 which we feel best reflect a real world workload. ATTO is also easy to obtain and run. Other benchmarking utilities may use fully incompressible data as part of their standard workload. Incompressible data can negatively affect benchmark performance on both the read and write speeds of our V300 drive depending on which NAND is being used. This is irrespective of the firmware revision of the drive.
Our products bring to market a real world workload as advertised under the conditions outlined in our documentation. All Kingston V300 SSDs bring an excellent user experience to our customers namely faster boot and shutdown, faster application loading, extended battery life verses HDDs, faster disk performance overall and most importantly a quality SSD product. For further assistance, please call us at 1-800-435-0640 (USA and Canada only) M - F 6am - 6pm PT and I or another available Technician will assist you. Please be sure to have the part in question on hand when you call.
Thank you for selecting Kingston as your upgrade partner.
The fact that they are using ATTO to benchmark drives isn't at all surprising. Every company that makes a Sandforce drive advertises ATTO scores because Sandforce is so much better at Compressible data. This also allows them to advertise their asynchronous drives with very high speeds. This is why I always advise against paying attention to manufacturer specs.
What IS interesting is that Kingston says "Incompressible data can negatively affect benchmark performance on both the read and write speeds of our V300 drive depending on which NAND is being used". They then go on to say "This is irrespective of the firmware revision of the drive".
It looks very much like Kingston has switched from synchronous to asynchronous flash in these drives. If this is the case then Kingston is doing something very shady and unethical. While their advertised speeds may be correct, the NAND changing in the drive is huge for performance.
If you have a Kingston V300(every case I've seen so far has been the 120GB capacity) check the revision you have and benchmark it. If you have a v506(product code-506ABBF0) and are willing to open it up and take a picture of the PCB/NAND modules I can probably confirm/deny this. I understand if you aren't comfortable doing that though.
You are no doubt correct about the type of NAND used in the lower performing versions of the V300. I posted the same thing in another thread weeks ago. I also agree about the firmware, which rarely affects performance very much if at all.
Manufactures will sometimes obscure the model numbers on chips, literally wiping off the printing with a solvent. Would I be surprised if that was done in this case? Not at all.
One possible way to check would be to find a very recent review of the V300, but we know which model would be sent for reviewing, don't we?
Storage Nut
yea, it is shady imo as well. I've noted it when I first seen reports about it.
Someone here reported a Mushkin Chronos Deluxe with async NAND before, when it should have had sync NAND. Mushkin however quickly RMA'd the drive for a proper one with sync NAND.
Jen-Hsun Huang fanboy
I'm one of the poor saps who bought one of these SSD's.
I received a Taiwan 506 and its ridiculously slow. ASSSD shows around 180 mb/s read speeds on fresh install win 7.
Personally I don't believe Kingston switched the memory chips and the fault lies in the firmware. I think the problem is just complete lack of caring and incompetence at Kingston, not duplicity.
The V300 uses a custom version of the sandforce firmware, its not the same. I figure messed up the 506 version and they are just too lazy to write new custom version for whatever reason using the 507 firmware update sandforce put out there.
Most people aren't going to realize the SSD is a lemon because they are ignorant and dont know any better. Look at recent review for the v300, most people who recently got one think its a great deal and dont have clue about how insanely slow it is. To them its better than their old HDD. Most people will never run any benchmarks, nor have they ever installed windows on a ssd before as this is most likely their first SSD. The only benchmark they will see is the Windows Performance Index which rates this SSD at 7.8 on fresh install. To them thats good enough.
Storage Nut
Im 99.99% sure the issues lies in the NAND rather than firmware.
You are 99.99 percent sure its the NAND even though you basically have no proof and we can directly measure the differences in the firmware versions which are massive. I'm not saying you are wrong, but I dont see you could possible be that sure of yourself unless you physcially took apart several drives.
Storage Nut
I have one that runs at new release/reviewed speeds in my server.
I'd update the firmware from 5.05 to 5.06, but the tool says there are no updates.
It is much more plausible that kingston used cheaper async NAND to save $ or because supply was low because performance results are similar to other sandforce drives that have cheaper async NAND. Rather than, that they tried to tweak the firmware to where performance would be similar to other SandForce drives with slower Async NAND when they used more expensive Sync NAND in the drive.
There are several problems with the "firmware is the cause of lower performance" theory:
What is the most costly component used in a SSD? The NAND data storage chips.
What component used in SSDs has decreased in price, causing SSDs to be cheaper? The NAND data storage chips.
What component used in SSDs has evolved from using an asynchronous (one data transfer per clock cycle) data transfer at a 66MHz clock rate, to a synchronous (two data transfers per clock cycle, as in DDR memory, Dual Data Rate) data transfer at 100MHz, 133MHz, and 200MHz clock rates (the latest types up to 400MHz)? NAND data storage chips.
What component used is SSDs was said to have a shortage of availability in 2013? NAND data storage chips.
What would be the easiest way to save money when purchasing NAND chips? Buy old stock asynchronous NAND chips running at 66MHz that virtually no one else wants.
The argument that many people won't know the difference between a poor and normal performing SSD is a good point, but the poor performance could easily be caused by asynchronous NAND. IMO it is much more likely to be the type of NAND used rather than the firmware.
One of the major selling points of the SandForce controller, as sold to SSD manufactures, is the manufacture has very little (if any) design and engineering work to do themselves. That is, the manufacture uses the "reference" board for the SSD, with the SF controller and associated components already engineered and tested, including working firmware (that's another story). All the SSD manufacture must do is choose the NAND and adjust a few things for each type of NAND, probably using the SF design documents.
Very few SSD manufactures using SF controllers modify the firmware much if at all, and I doubt that Kingston is one of them. The main one we know that has modified the firmware is Intel, and AFAIK the other is SanDisk. If Kingston is using "5.06" as their firmware version number, that exactly fits the official SandForce 5.0 firmware release line, which was 5.0.0, 5.0.1, etc. IIRC, SF firmware 5.0.3 finally fixed the malfunctioning TRIM bug introduced in the new SF 5.0 firmware line.
Assuming that Kingston modified the SF firmware, and their 5.06 firmware causes poor performance, why not just go back to the 5.05 firmware? Why would they even need a new version of the firmware, if the only difference is the location of the factory assembling their SSDs? One answer to that question is to accommodate different NAND chips, like asynchronous.
Do we have examples of very similar SSDs that differ in performance due to the NAND chips they use? Yes, the OCZ Agility 3 and Vertex 3.
IMO, the OP virtually proved his point (and mine) with the quote from Kingston stating that the NAND rather than firmware would cause a difference in performance. To many details add up add up to the use of asynchronous NAND in some production runs of the V300.
I also see a different clue in the OP's statement that, "every case I've seen so far has been the 120GB capacity". With the shrinking of the NAND to the 2x nm level and less, it's possible to put 60GB of user space on one NAND chip, or possibly even more. The potential problem with that is the number of channels that NAND chip has to connect to the controller does not increase, due to the physical design and standards of the chip package. Larger capacity SSDs with more NAND chips can use all the channels the controller has, but the 120GB V300s may be limited to the use of four channels instead of the usual eight. That is pure conjecture on my part.
Believe me, I would hate it if I had purchased one of the "5.06" V300s, and I get no satisfaction from writing this. I wish it was a firmware issue, but IMO it isn't.
Discussion Starter · #9 ·
Yeah I don't think you understand how little the firmware affects performance. Especially on a Sandforce SSD where every manufacturer is extremely limited in the scope that they can actually change it. There is a reason why every Sandforce drive performs more or less identically.
So, I opened my taiwan 128 gb 506 firmware v300 and the chips were wiped clean with solvent. There's no real information. Kingston then printed their label on top of the chips as if they actually make the chips themselves. I bet no other Sandforce SSD does this. If you are using quality NAND, they would be no reason to wipe off the original label.
I'm now a believer. They must of switched the chips like you said okp11.
I bought one of these three days ago, the firmware number is 5.21. I get the same results as 5.06, further backing the claim that the hardware's at fault here.
http://i.imgur.com/KF2N2WT.png
You can only get better results with the 0-filled(Crystal) or uncompressed(ATTO) data sets, but for me, even that's just 400/250.
Storage Nut
well you are also limitedby the marvell sata port you have the SSD connected to.
Absolutely true regarding the 400/250, but would that affect the other low benchmarks?
Of course, it will affect everything. First a Vertex 4 on a Marvell 9128:
Next same Vertex 4 on an Intel SATA III port:
All SandForce based SSDs do not do well in AS SSD, that is a given. But that is only in the write scores, they still have normal read speeds.
Any of the Marvell 91xx SATA chipsets are connected to one PCI-E 2.0 lane (hopefully PCI-E 2.0) whose speed is... 5Gb/s max. Is that the 6Gb/s of SATA III. No, the end.
Note the write speed access times on the Kingston SSD. If that does not say "asynchronous NAND", the rest of the results do. (I know the M4's later firmware has even worse write latency, but we know that's the firmware.)
Asynchronous NAND is Single data rate transfer at 66 MHz, while Synchronous NAND is Dual data rate transfer at 100, 133 or 200MHz.
Or Async is 66MHz effective transfer rate vs Sync at 200, 266, or 400MHz effect transfer rate.
66 x 3 = 198. 172 x 3 = 516. I'm sure you all can figure out where these numbers came from and what they mean.
I have a 5.0.5 and 5.0.6 version and am seeing the performance differences. After the third attempt to get a specific answer Kingston support verified in writing what you folks suspected.
"Hello [Scootcha],
We use NAND from various manufacturers both synchronous and asynchronous. The first revision you have is made with synchronous and the second asynchronous.
Both versions however conform to our specifications as stated in the datasheet and will enable a good user experience as expected from SSDs. Fast boot, fast application performance, improved battery life and much better random performance versus traditional HDD technology.
If you have any other questions or concerns, please feel free to reply to this e-mail with full email history. Thank you for using Kingston on-line technical support."
"Hello [Scootcha],
Nice work Scootcha! But some Kingston rep may be getting fired for revealing the truth, I hope not. Unfortunately the saying "you get what you pay for" applies in this case. Not that anyone had a clue about this, and didn't they kinda slip these in around the holidays when things are on sale?
Great work on your part Lex Luger! Thanks for doing that, we'd love a picture of that if possible.
Some SSD manufactures like OCZ will purchase raw, unpackaged NAND dies, and process it themselves into NAND chips. That allows them to label the chips as their own. Apparently that is cheaper overall too. NAND is also binned like DRAM chips, so this practice hides that as well as the source of the NAND dies (such as IMFT or Toshiba.)
While I don't know if any NAND die manufactures are still producing async NAND currently (could be used in cell phones, cheap tablet PCs, etc) perhaps they do. Or they found some new old stock async NAND dies. Kingston might be doing the same thing as OCZ, packaging the async NAND dies themselves.
Otherwise, I agree there is no reason to hide the type of NAND chips used if they are a good product. It's still possible the chips were wiped of their original labeling, and relabeled as Kingston. Given the current state of SSDs, going back to async NAND is really bad.
Thanks to you and okp11 for broaching the subject which put the bug in my bonnet.
I bought my 5.06 well before the holidays. The Kingston rep and management should know that my reply would be made public since he escalated it and I included a link back to the discussion here when I opened the original ticket with them. It did take a few attempts at asking the very specific question to get it out of them and I refused to discuss it of the phone when they tried that route.
My closing response to their trouble ticket expressed empathy for the support staff since I have been in their position and it is not fun. Also that I probably will not be buying any more of their products in the near future and hoping that Kingston was not being "OCZ'ed." Time will tell.
I see, I wasn't sure when the 5.06 models were available. Smart thinking to get it in writing!
Yes, the support staff gets to suffer while the decision to do that was done elsewhere.
Good comment about being OCZ'ed. OCZ seemed to back off after being caught on that SSD capacity difference, but who knows what else is hidden and undiscovered. When I read they were packaging their own chips from raw NAND dies, I did not see that as a benign thing. The user can detect async NAND quickly, but low grade sync NAND is not obvious in the short term. I'm NOT saying and DO NOT know if anything like that was done, pure speculation on my part.
As for Kingston, was it worth it to ruin your reputation among PC enthusiasts? Or are we to blame for not paying close attention to the fine print on the benchmark criteria for the specs? Even if it is the latter, most enthusiasts won't see it like that IMO.
I also have this issue to, I swear I got scammed out of money. I have the latest Amd Sata AHCI drivers, bios, and sata 3 6.0gbps ports enabled. I also have the 5.06 firmware. I really hope that Kingston just F'd up on there firmware.
Also one more thing, do I have the right Sata 3 AHCI driver for win8.1 64 pro? I have seen people with low scores like mine, but I don't know if I have drivers 100% correctly configured. Any Suggestions?
My system also froze in the Benchmark, around the Acc. Time.
COME ON KINGSTON GET YOUR GAME ON! WE DON'T PAY FOR *****.
Discussion Starter · #20 ·
Its the NAND. Kingston confirmed it above in Scootcha's comment. They did in fact switch to asynchronous.
1 - 20 of 165 Posts
