PSP 3000 D'PAD Problems.
2185 Views 3 Replies 3 Participants Last post by  DennisC
So it's not the D'PAD that's messing up, its the sticker underneath it. It seems like the Up and Down are both stuck. I have tried lifting up the sticker, but I don't want to remove it because if I do it won't work at all. Not even the analog stick. Unless there is a way to make it default. I am asking...What should I do? Please reply, or send me an e-mail.
1 - 4 of 4 Posts
So it's the conductive print circuit that is stuck?
Well tbh, i wouldn't pull it apart in case you can't get it back together.
Is it not still under warranty?
i havent removed the last screw. so i guess so. but i dont have the money to send it off. is there anyway i can get it fixed?
I have the same problem with 2 of my slims but with the L trigger and a home button. They all use the same kind of ribbon. You need to replace it with a new ribbon. It can be bought on focalprice.com.
1 - 4 of 4 Posts
