1 - 7 of 7 Posts
Hey, can anybody tell me if this memory works in the Sony PSP?
http://www.newegg.com/Product/Produc...82E16820171130
I know that it should because its Pro Duo but in all the other PSP memory it says PSP-compatible in the specs and this is for my cousin in another country so I don't want it to not work then have him pay to ship it back to me for a replacement.
should do, ill get back to you for sure in a sec, i have the sony 32mb one in my room somewhere if thats pro duo then any pro duo should fit
you need MEMORY STICK DUO, its probably the same though, but you might be better off finding some non pro version just to be on the safe side hope that helped.
Reactions: JacKz5o
basically the main stuff says memory stick duo on it, so it should technically work.
Discussion Starter #6
I just checked on the SanDisk website and all of their PSP compatible memory says Memory Stick PRO Duo on it. I guess i'll go for it
Yep it'll work get. "thedarklordjay" is misinformed. Pro Duo is just a cheaper, faster, better version of the Duo.
1 - 7 of 7 Posts
