1 - 13 of 13 Posts
Hi. I was just looking at my PSU voltages, and notices that the 5V was especially low under load (4.8V) while it is abt 4.9V idle. My overclock that has been stable for 6 months is no longer stable, and was wondering if there is anything causing this? Do I need a new PSU?<br />
<br />
<img src="http://www.freewebs.com/cause_of_chaos/5V%20Problem.JPG" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
cause_of_chaos
get a new quality power supply.. u get out of it what u pay. i reccomend antec. never had any problems with them. but iv only had to buy 2 so far <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Yea and your 12V rail Voltages dont look too good either, I mean 12.35V I get about 12.1V on my Antec.
Agreed.. I am more concerned about the 12V rail, esp. since Asus Probe does tend to report slightly low voltages (at least, that's my experience).<br />
<br />
Get a new, quality, PSU.
I remember when......
Funny, my OCZ shows similar readings in PC Probe 2.<br />
<br />
12v - 12.25<br />
5v 4.94<br />
3v 3.3
Interesting..<br>
Maybe there is a newer version of Probe in which they fixed things...
Well, this is PC Probe 2 <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps"><br><br>
So it's probably coded better than the older PC Probe, but it won't work on older boards IIRC......hopefully this GameXstream is working right <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
My FSP (which is identical to the GameXStream) consistenly reported like 12.3V on my old rig (In BIOS 12.05V, in Windoes 12.3V). In my current rig (new mobo, CPU, RAM, everything else the same), it reports 11.98V in BIOS, but 11.76V in windows<br><br>
Should do multimeter thing... hehehehe those sensors are wacky
<div>Originally Posted by <strong>Thumper</strong></div>
<div style="font-style:italic;">Well, this is PC Probe 2 <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps"><br><br>
So it's probably coded better than the older PC Probe, but it won't work on older boards IIRC......hopefully this GameXstream is working right <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"></div>
</td>
</tr></table></div>
your PSu should be fine, when i had your PSU I got fairly the same readings on asus probe too. Then I used a multimeter and all was well.
Discussion Starter #10
Heh, my spelling SUCKS!!! What wattage PSU would you peeps recommend, as I am aiming for a decent Crossfire setup for my next rig, and I want to use my next PSU for that too.<br><br>
Antec has the 2.0 and the Trio. What would be better as they are a similar price. Also have my eye on an OCZ ModStream. Any thoughts?<br><br>
cause_of_chaos
My two picks:<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817703005" target="_blank">PC Power & Cooling Silencer 610 EPS12V EPS12V 610W</a> $159.99<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817341002" target="_blank">OCZ GameXStream OCZ700GXSSLI ATX12V 700W</a> $154.99<br><br>
I replaced my Antec Truepower II 550W when I went Crossfire.... <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Administrator
Well that PSU is ait over the specs it should be on the 12V rail. However i would use another program such as Speedfan to see if you get a different result. I would also concure and say this psu is great : <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817341002" target="_blank">http://www.newegg.com/Product/Produc...82E16817341002</a>
Discussion Starter #13
Newegg is out of the question, as I live in the UK. Overclockers.co.uk has it for £106. Might go for that. Cheers!!!<br />
<br />
cause_of_chaos
1 - 13 of 13 Posts
