1 - 6 of 6 Posts
hello, i m willing to buy these components for my pc:
FX x8 8350 CPU + Hyper 212 Evo
Gigabyte 990FXA-UD3 Mobo
16GB (2x8GB) RipjawsX DDR3 1600MHz CL10 Dual Kit Ram
WD 1TB Caviar Black Sata 3.0 64MB Cache 7200Rpm Harddisk
Sapphire R9 290 TRI-X OC
And i m willing to overlock both cpu and gpu so which of these PSUs i should get?
Thermaltake TOUGHPOWER XT 80PLUS 775W http://www.newegg.com/Product/Product.aspx?Item=N82E16817153127
Seasonic G-750 80PLUS GOLD http://www.newegg.com/Product/Product.aspx?Item=N82E16817151132
I be happy if u help me choose plz, thank you.
Senior OCN Member
G is the better unit of the two, but you dont need 750 watts for one video card you can do with 550 watts
Senior OCN Member
It says 750watt on the manufacturer site for sapphire r9 290 tri-x. If anything happens to my gpu it s out of warranty cus of i didnt use their recommendation PSU? And for u 750 W s even enough for 2x R9 290?
Senior OCN Member
That recommendation is based on a peak rated PSU not a continuous rated PSU so no you dont need 750 watts for it
And yes unless you are going to overvolt the cards you can have 2x cards on a 750 watts
1 - 6 of 6 Posts
