Well i bought some electrical tape for my PSU wires and before i turn on my computer to apply it on......is it safe and......im guessing it wont do anything and its been done before but just want some opinions
well if you asking if it is safe to use a a cheap sleaving... yes it will work, it may make the wires a little still to bend, and when/if you decide to peal the tape off it will be very sticky.... but it will work fine.
After taping you could always apply coil or split sleeve like you get from the autoparts store if you like...it's very inexpensive. A little heatshrink slipped over the ends of split sleeving keep it together pretty well.
Well i applied the electrical tape, but now the monitor wont turn on and making me REALLY mad this is about the 3rd time that my 6600GT and my FX5200 will not get a pictures from the monitor i beleive its my Motherboard, i hate my life!
1 - 4 of 4 Posts
