First of all, you can run 3 way SLI with GTX460. 2 Way is max.
And for that, a quality 750W is more than enough.
if your running 2 way sli, youre using the 3rd 460 just like any other Phsyx cardOriginally Posted by Cee;12998223
Agreed - TX950, and you'll get full use of all its pci connectors!Originally Posted by appleg33k85;12998238
You would only need 6 6pin pcie - most high end psu's have that - the Corsair TX950 that I had, had that setup, my HX1000 has 8 8pin... - and to the above poster,
if your running 2 way sli, youre using the 3rd 460 just like any other Phsyx card![]()
My bad, all I saw was '3' and 'GTX460'..Originally Posted by appleg33k85;12998238
Originally Posted by windfire ![]() I think people are just confused because OP uses ''3 way sli'' in the title. Anyway, Corsair HX850 (US$155) and TX950 (US$140) both have six 6+2-Pin PCIe connectors. The former has modular design while the latter has more power. http://www.newegg.com/Product/Produc...9011&Tpk=hx850 http://www.newegg.com/Product/Produc...82E16817139013 |
