1 - 3 of 3 Posts
I was wondering I have an antec true 430 watt psu. It has two fan one normal spot one on the bottom. I noticed these fans dont seem to push liek any cfm @ all id b surprised if they were over 13cfm..
1.) Would replacing these fans with higher cfm one be a bad idea?
2.) would replacing these fans with higher cfm ones help me at all?
it would move a lot more air but you dont need it
power supplies come with what they need, and unless your comp is at 90% or over load constantly, theres nothing to worry about
plus replacing fans isnt as simple as adding one to your comp, the wires of those fans are saughtered (spelling?) directly to the card inside the psu, so unless u remove those and re-saughter on the new fan, you cant change them
i wouldnt worry at all, unless u start to see crashing then i'd be suspecting that the psu was faulty or overheating
1 - 3 of 3 Posts
