PSU is loudest Component
608 Views 15 Replies 8 Participants Last post by  Blinx
I've recently discovered that my PSU is the loudest component in my PC. It is a 600W OCZ GameXstream PSU.
When all my fans are on low, i can hear a clicking from my psu. Upon further investigation, I found out that it was the fan. It is a dual ball bearing fan, so should not have a problem with being run horizontally.
The fan has always been a bit strange, the LEDs in it take about 5-10 mins to turn on.
So is there any way to fix this without opening my psu and voiding the 3 year warranty, or will i have to replace the fan with a higher quality one?
thanks
1 - 16 of 16 Posts
Replace the fan with a quieter one, keep the old fan. You will still probably void the warranty, but if something happens put the old fan back in, and send it in. Ya never know.
any recommendations for the new fan? and should i wear some rubber gloves, as i heard that PSU retain some electricity after they've been unplugged, as i don't exactly want to get a shock
I just replaced the 120mm fan in my CoolerMaster 600W with a Yate Loon. I wasn't wearing gloves, but you could if you felt it was necessary. Also, check the plug. The fan in mine had only two wires as opposed to three, and they were backwards.
They'll know as he'll have to break the sticker to get into the PSU cover.
If the PSU is about 2 years old, it maybe worth replacing the fan, but from my experience, the PSU fans are harder to find a close replacement (you're left guessing the watt/amp on some of them, as they're so generic to not even list it).
If your PSU is the same ones offered at Performance-PCs, you can check what fans they'll replace in a custom mod. It'll give you an idea what watts/amp fan that can be used in it.
Get at RMA.... that PSU shouldn't be that loud. The LEDs shouldn't take time to turn on.
Ah, your saying that the fan is not the usual 3 pin connector?. Didn't think of that
The PSU is about 3/4 of a year old.. not much point RMA-ing it.
With the LEDs, they start off being off, then over a period of about 5 mins they slowly get brighter...
I'm sure it's nothing compared do my oczproxstream
It does the clicking sound even if the pc is shut down. But i don't mind, the sound makes me sleepy !
If you are going to open it, leave it disconnected for at least one day, till all electrical charge have gone away
Dang!
My Corsair HX1000 is starting to give away a sand grinding sound, probably dust in it...
Really annoying since I didn't buy it for $315.91 so that it can make strange noises after some months...
There's something wrong with it. Your options....
1) live with it
2) RMA it
3) fix it yourself (and void warranty)
http://www.ocztechnology.com/product...dia_sli_ready_
3 year warranty backed by OCZ's exclusive PowerSwap™ Warranty replacement program. No more endless return-for-repair loops!
OCZ Technology Group offers a 3 or 5 year PowerSwap™ Warranty on all PSUs
All OCZ Power Supply Families feature an exclusive warranty that allows you to "swap out" a defective power supply. This eliminates the hassle of return-for-repair loops that other companies put you through, saving you time and ensuring you will receive a 100% hand tested, fully functioning unit as a replacement. Your defective power supply can be returned for replacement at any time within the specified warranty period. All replacements are guaranteed to operate without issue and to full specification.
ok, but what would i say for the RMA? Fan LEDs are slow to start, and the fan is the loudest thing in my case? i don't see that working....
Maybe the fans are low to start because it does not run at full capacity at first. The speed of the fan goes up as the heat builds.
that is a very good point actually. I didnt think of it being temperature controlled..
Faulty fan....
spose so....
ok, here is a VERY noob question: I've never had to do a RMA (thankfully), so how would i go about one? Contact the retailer or the manufacturer?
EDIT: Just remembered something that voids the warranty i believe: There were some P7 connectors with the PSU. Research showed that they were used to old floppy drives and such. So i cut them off as they were taking up lots of space and made cable management difficult.
So essentially i've voided the warranty by damaging the PSU
You are safer off replacing the PSU. From what I have read before is that unless you REALLY know what you are doing, accidentally touching one of the many capacitors in the PSU can cause a shock strong enough to kill you. I would rather spend a bit of money than put my life at risk.
1 - 16 of 16 Posts
