I'm having some problems with my new PC. It was running fine for the first month, but then the screen kept freezing and it started turning itself off.
Then when I tried turning it on it either loaded up saying windows encountered an error and it freezes again or the system comes on but the screen doesn't load up.
After a while the the system woudn't turn on at all so I thought it must be the PSU in the system. But i put another one in and the computer started up ok and seemed alright, but when i turned it off and tried to start it up again there was no power. The PSU was working fine before i put it in. Does anyone have any ideas what it could be?
My System:
Pent64 Dual Core 6.8Ghz 4GB/250GB & nVidia 512MB XLgt
Thanks
My System:
Thanks
