1 - 11 of 11 Posts
Hey all! Total PSU newb here looking for a bit of help
Power Supplies, I get the basics, kinda. But theres something Im curious about
If I get a PSU that is `overkill`, does it draw more power for the same load as a non-overkill PSU? For example, lets say my rig runs around 300-350W. Would a 400W PSU be ideal (electric bill, etc) or would a 750W PSU still draw the same amount of power (and simply have the capacity to draw more if needed).
Second, what size/wattage PSU would you suggest for the following two/four rigs:
  1. AMD Phenom II x4 955
  2. Intel Core i7 920/930
Components
  • 1x nVidia GTX460 / 2x GTX460 running in SLI
  • 2x 1TB SATA II/III HDD
  • 2x2GB DDR3 1600Mhz
  • 1x DVD & CD +/- RW
A PSU running at full load will not last as long as an overkill PSU running at lower power. But you shouldn't go too far with the overkill. The sweet spot is to run the PSU at 70-80% of capacity for efficiency. However, many of the newer gold rated units hold the numbers right up to full power. I'd still go with having a bit more power so it's back to the 70-80% figure.
I'd suggest you go with a 600-700w unit, the seasonic X-650, corsair AX or Antec TPN will do you fine.
Baller on a Budget
Yeah a PSU only draws what it needs. However, large differences between capacity and actual load will hurt efficiency numbers (i.e. it would be bad to use a 1000W PSU for a 150W system). I would get the Antec True Power New 650W, X650 is amazing but costs alot.
Discussion Starter · #6 ·
Originally Posted by galaxyy View Post
Here use this calculator to figure out how many watts you need.
http://extreme.outervision.com/psucalculatorlite.jsp
Then check out the PSU recommendation thread.
I have and that thing seems highly inaccurate to me. Changed nothing, selected PIIx4 955.
~ 136w min & 186w recommended at 90% load.
~ 163w min & 213w recommended at 100% load.
This means fans and everything is set to 0. Basic mobo, etc. Curious to see 163w min at 100% load on a CPU that is 125w max TDP. Unless Im overlooking something obvious which happens often enough with stuff I only barely grasp ^^
Originally Posted by Cloud007 View Post
Is that thread even useful anymore? It was made back in 2007 =/.
Ive noticed many `sticky` threads with recommended parts are highly out of date on other parts of this forum.
check the small edit footnote.
That will tell you if its up to date.
Tator Tot is keeping it up to date, it's very current. Last updated like one or two weeks ago I think.
Ah, my mistake. Forgot to check the time it was last updated.
Are all the PSUs in the recommended list fairly quiet? Im sure being on that list likely means their noise & ripple is low, but perhaps not necessarily their acoustic noise. Tis one thing I forgot to mention. I'd like to keep the rig Im building fairly quiet
My thread is up to date as of a week ago, and will have some significant changes soon-ish.
Currently I am waiting on PSU Manufacturers to release models (some which have been reviewed, some which were not yet.)
1 - 11 of 11 Posts
