1 - 20 of 20 Posts
My stock PSU is a 300-watt Bestec.And I've added other components to my PC and need a real PSU now!<br />
<br />
AMD Athlon 64 x 2 3800+ 2.0GHz Dual-Core<br />
1GB(2 x 512MB) DDR SDRAM PC-3200 400MHz,184-pin Corsair value select<br />
250GB SATA 7200rpm HDD<br />
250GB Seagate Barracuda 7200.10 SATA 3.0Gb/s 16MB HDD<br />
160GB Western Digital Caviar RE 7200rpm 16MB SATA 3.0Gb/s HDD<br />
<br />
16 x DVD/RW dual-layer Lightscribe drive<br />
8-channel High Definition audio<br />
eVGA 7900GS graphics card<br />
two extra in case fans: 80"mm Thermaltake<br />
19"Samsung Flat LCD Monitor<br />
Logitech G5 Gaming Mouse<br />
Logitech G15 Keyboard<br />
Logitech X-530 Surround Sound Speaker System<br />
<br />
And there will be three devices plugged into my 2.0 USB ports<br />
<br />
My PSU budget is $185.00
I would try a PSU with a 500W rating, and 2-3 rails with 18A+ (rough amperage) on each.<br />
<br />
How about a budget... Do'h! NM <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> saw you have a great budget! <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
<br />
OCZ - non-modular <br />
<br />
Reputable manufacturers: Antec, OCZ, Enermax, Silverstone.
^^That's my user name^^
Can't go wrong with an Antec: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817371001" target="_blank">http://www.newegg.com/Product/Produc...82E16817371001</a><br />
And I would add some cable sleeves to it: <a href="http://xoxide.com/sleevingkit2.html" target="_blank">http://xoxide.com/sleevingkit2.html</a><br />
Or, you could get a PSU with the cables sleeved, I would suggest one of these:<br />
<a href="http://www.newegg.com/Product/ProductList.asp?Page=1&CompareItemList=N82E16817148025.0%2CN82E16817148026.0%2CN82E16817148023.0%2CN82E16817148024.0%2CN82E16817148022.0%2CN82E16817153029.0%2CN82E16817711001.0%2CN82E16817148019.0%2CN82E16817103940.0%2CN82E16817341001.0%2CN82E16817153032.0%2CN82E16817148028.0%2CN82E16817153042.0%2CN82E16817153030.0%2CN82E16817148021.0%2CN82E16817103941.0%2CN82E16817153033.0%2CN82E16817148030.0%2CN82E16817148029.0%2CN82E16817341002.0%2CN82E16817153031.0%2CN82E16817148020.0%2CN82E16817116002.0%2CN82E16817104014.0%2CN82E16817371001.0%2CN82E16817153040.0%2CN82E16817153034.0%2CN82E16817104015.0%2CN82E16817153039.0&bop=AND&Submit=PROPERTY&SubCategory=58&Manufactory=1919%2C+1516%2C+1998%2C+1389%2C+1849%2C+1885%2C+1379%2C+2120%2C+1550%2C+9830&PropertyCodeValue=1314%3A14179%2C1314%3A14177%2C1314%3A14178%2C2331%3A14181%2C2331%3A14183%2C2331%3A14182%2C2954%3A18939%2C2954%3A18938%2C2947%3A18603&OEMMark=0" target="_blank">http://www.newegg.com/Product/Produc...8603&OEMMark=0</a><br />
Not all of them are sleeved, but most of them are.
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817341002" target="_blank">http://www.newegg.com/Product/Produc...82E16817341002</a><br />
<br />
Get it whilst still in the sale.
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817703005" target="_blank">http://www.newegg.com/Product/Produc...82E16817703005</a>
i second the one busa picked out, its the one i was going to recomend.. And now a days you dont want a psu with less than 24 to 26 amps on the 12volt side. This one has a beefy 49 amp single rail, which is better than multi rails for stability. Most multi rail psu tap into the same rail anyways.
Discussion Starter #7
I don't think that'll fit my pc tho??<br />
<br />
Here's my current psu's specs:Those pc & cooling psu's are big.LOL.............<br />
<br />
<br />
<br />
<br />
dimensions are : 5.9"W x 3.4"H x 5.5"D <br />
140L x 150W x 86H mm
ahh you have the factory hp case, ewww... might want to look into getting a different case. So you can upgrade ect, give me the model number of your pc and ill look it up and see what formfactor it is.
Is the system an "HP" system...or just in the case? If it's an HP then you might have to get an oem psu. If not then you might want to look into a new case also. with the savings from your 185 budget your 1/2 way there already.
Discussion Starter #10
It's a HP Pavilion Media Center a1430n<br />
And no it supports standard size psu's my stock is 5.9" x 3.5 x 5.5
Discussion Starter #11
<div>Originally Posted by <strong>hp-gamer</strong></div>
<div style="font-style:italic;">It's a HP Pavilion Media Center a1430n<br>
And no it supports standard size psu's my stock is 5.9" x 3.5 x 5.5</div>
</td>
</tr></table></div>
The pc & cooling is 7.1" D which is the only number thats to big;for what I can fit.
Discussion Starter #12
Here's the exact PSU thats inside my pc right now!<br><br><a href="http://www.atxpowersupplies.com/300-watt-power-supply-bestec-atx-300-12zcdr.php" target="_blank">http://www.atxpowersupplies.com/300-...300-12zcdr.php</a>
Discussion Starter #13
I'am go with one of these PSU's.They all will fit my case:<br>
1.)Enermax Liberty 620w<br><br>
2.)Corsair 620w<br><br>
3.)Corsair 520w<br><br>
4.)OCZ GameXStream 700w<br><br>
5.)OCZ GameXStream 600w<br><br>
6.)Seasonic S12-500
Discussion Starter #17
New case for what?My case supports standard sized psu's.Which just means that I won't be buying one of those psu's with larger than normal depth<br>
I like my hp case and will be keepin it.The corsair 620 will fit.The PC & Cooling won't.But ole well.Just won't be spending my lil $200.00 for that one then.LOL.................
Discussion Starter #19
Are these dimensions to big?<br>
150(L) X 165(W) X 86(H) mm<br><br>
ZALMAN ZM600-HP<br><br><br>
ZM600-HP is ultra-quiet power supply complies with ATX12V Version 2.2, and supports the lastest dual-core CPUs(Intel Core2 series/AMD Athlon64-X2 series), as well as the lastest dual graphic card systems(SLI<br><br><br><br>
Heatpipe Installed for Maximum Cooling Performance and Ultra-Quiet Operation<br>
A heatpipe with ultra-high cooling performance incorporated on the power supply’s main<br>
rectifiers enables high load operation even at low RPM for a dramatic reduction in noise levels.<br><br>
Improved Power Factor & Reduced Harmonics through Active PFC<br>
By implementing Active PFC(Power Factor Correction), the Power Factor (PF) is improved from 75% (Passive PFC) up to 99% while harmful harmonic frequencies are reduced to meet the line harmonic distortion requirements of IEC61000-3-2 Class D.<br><br>
High Efficiency Design<br>
This power supply is capable of reaching a maximum of 84% efficiency(230VAC, Full & Typical Load) through its use of high switching frequency and low power-loss circuitry.<br><br>
ATX20+4 Pin Main Connector<br>
ATX20+4 pin main connector broadens the range of motherboard compatibility.<br><br>
Supports ATX12V CPU 4-Pin and EPS12V CPU 8-Pin<br>
Two ATX12V CPU 2ⅹ2(4-Pin) power cables can be combined to form an EPS12V CPU<br>
8-Pin power cable.<br><br>
Dual PCI Express VGA Power 6-Pin Connector<br>
Support Nvidia SLi dual graphic card systems.<br><br>
Module Cables<br>
Modular cables provide organized cable management and improved air circulation inside the computer case.<br><br>
Ultra Quiet 120mm Fan<br>
Ultra quiet 2-Ball Bearing 120mm fan maximizes the airflow and minimizes the noise level enabling a noiseless computing environment with optimized cooling.<br><br>
Four Independent +12VDC Outputs<br>
Four +12VDC rails supply power independently to the CPU, VGA, motherboard, and peripheral<br>
components for the highest level of stability and performance.<br><br>
EZ Grip Connectors for ODDs & HDDs<br>
EZ Grip Connectors for easy removal of the plugs from ODDs & HDDs.<br><br>
Gold-Plated Terminals<br>
Gold-plated the terminals minimize power loss by reducing contact resistance.<br><br>
Sleeved Cables<br>
All power cables are sleeved for easy cable management and improved air circulation inside<br>
Multiple Safety Features<br>
Over-Voltage Protection, Over-Current Protection, Short-Circuit Protection, Under-Voltage Protection, Over-Temperature Protection.<br><br>
Internal Blue LED<br>
Blue LEDs are installed inside the power supply for cool aesthetics.<br><br>
WEEE & RoHS<br>
Complies to WEEE & RoHS Environmental Directives of Europe.<br><br>
- WEEE : Waste Electrical and Electronic Regulations<br>
- RoHS : Restriction of Hazardous Substances Regulations<br><br>
International Safety and EMC Certifications<br><br><br><br>
Specifications<br><br>
Output Power Cable Specifications<br>
[Cable Lengths & Connector Names]
Discussion Starter #20
<a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=373518" target="_blank">http://www.zipzoomfly.com/jsp/Produc...uctCode=373518</a>
1 - 20 of 20 Posts
