Pull + Push orientation fans on rad?
287 Views 3 Replies 4 Participants Last post by  ira-k
what direction do they go?
air flow direction?
1 - 4 of 4 Posts
two ways to find out.
1. is to look on the side of the fan for some arrows. you will find two of them. One arrow shows the direction of the spin and the other the direction of the air flow.
Plug it into a molex and hold on tight while you power on your board and then unplug and shutdown.
3. Fan direction is alway blowing where the sticker and the wires are exposed. the plain side is the suck side.
Heres your answer here, the fan will blow out the side with the wires and pull from the exposed side.
Have them both blowing in the same direction, one pulling, one pushing. <rad<
1 - 4 of 4 Posts
