A flow meter of some description is what you're after.
Bitspower and Koolance make models that convert the flow rate into an rpm signal that you can plug into a mobo fan header.
Either set up BIOS so the pc shuts down when under certain rpm
or use software based monitoring to do the same thing, such as speedfan.
If you want to spend a bit more and get the best - with a whole lot more to offer as well, there is only 1 ......
Aquaero 6XT
Aquaero 6XT
