Punkbuster and Windows 7 Question *Solved*
429 Views 7 Replies 7 Participants Last post by  ACHILEE5
Hi
As punkbuster had problems with Windows 7. When i installed Call of Duty World at War, I didn't install it!
But now I want to play it online and can't because of not having punkbuster installed
So can I install it now, to work with Call of Duty World at War?
Or do I need to re-install Call of Duty World at War with punkbuster?
And if so, what happens about installing the punkbuster that didn't work?
So how do I do it lads
Thanks
AC
1 - 8 of 8 Posts
install punk buster off your disc, then go hear and get the update for it.. should be fine. i play 3 games that use PB and i have no problems as long as i update them manually.
I had a prob with PB and CoD. I dl'd pb and installed but it didn't work. Tried lots of things. Eventually put pb setup.exe in CoD directory and after patching cod it worked perfect.
just install it off the disk and leave the multiplayer side of the game idle for a while and it should update itself to the latest version itself. If not, just go to the even balance site and manually update it.
I've found that WAW has no problem with PB messing up, i only had problems with COD4
I tried this that Modki linked and got this
And when playing online got this
So then installed PB from the WAW disk, and it's Sorted
Thanks Lads
1 - 8 of 8 Posts
