How many of you guys actually run P95 twice because you just want to be sure that it is stable? For all of you would be overclockers out there, I purpose a challenge. I do not see anyone who is more meticulous with stability than I. Just because you are 12 hours stable, doesn't mean all that much considering that you can only get some errors once you have reached the 16 hour mark. Stable is stable right? Then prove it. My findings are too that on SB and IB that you actually need to run P95 for two 24 hour runs back to back. While the first one will pass, often times the second one won't. This would mean you would need to do it again after the first passing after the second attempt failed. True, it would never probably crash in real world use, but once again, stable is stable so why wouldn't you want to be sure that it was stable even in testing and extreme load? So, try or don't, rerunning Prime95 and see if you are actually stable.
Edit: This was my 1,000th post, too!
