Originally Posted by Tatewaki If you cannot do push-pull fan config on the rad and can only do either push or pull, which one is better? |
Originally Posted by Crashed taking the heat away from the rad is more effective.. think about the radiator of a car.. the fan(s) are behind the radiator and pull the air thru it to cool it down.. |
Originally Posted by Lostnhell Here is how I see it. Pushing guarantees that all air from the fan will be projected straight through the radiator. Pulling has chances of pulling air from the gaps in between the coils and in the small space between the fan mounting and radiator mounting. View the pict to see what I am talking about. |
Originally Posted by Towlieee I would think there wouldne't be any difference, as long as both setups are exactly the same... If your push setup uses 3/4" shroud and its 100% sealed, then a pull setup using a 3/4" shroud and being 100% sealed should pull the same ammount of air.... at least thats how I think it works... |
