You do not have the ability to play with your vcore on that motherboard. ECS is well known to not include any robust overclock bios settings. You will also find that the temperature/voltage readouts are not all that good. It's a good thing that the Prescott processor is not all that receptive to voltage changes which allows you to pump the fsb prettyk well. I would test it out for stability with Prime95 though.
R
R
