1 - 4 of 4 Posts
I have decided to put my ITX board inside my full rigs case, and use it for a server/torrent box. The ITX rig will get 2 of my f3's and a WD black in RAID 0.
I also want to keep the ITX rig silent so I will keep useing the D14 I have on it for now. The only problem with that is that leaves no room for the second PSU, so I will have to get a small PSU that will fit.
Here is my current plan:
The blue is the HD rack that comes with the case, and the red if my ITX rig.
The cool thing is the HD rack fits with enough room for a DVD drive under it. So all I need to so is drill the holes, and bolt it in. The greens is about where i want to mount this PSU . Though I might have to mod the PSU a bit for it to fit.
There is 2 top 140's, a rear 120, and 2 front 120's. The hd rack is the on that comes with the case, and the large part of the red box is the D14.
1 - 4 of 4 Posts
