Originally Posted by LiquidForce
id say dont go higher than 75.... if it is stable then take the voltage down a tad and see if you can shave a few *C
alright and yea i tried droping voltage just barely and bsod'd a couple minutes into stress test so i bumped and get higher temps im pretty sure im right at the perfect vcore for me
Originally Posted by x2s3w4
Have you tried reseating your heat sink to get better temps? How did you apply the thermal compound?
How high is the CPU voltage?
nope im pretty sure the seating on my hsf is fine ill do it sometime later, i applied my as5 with the baggy trick the way i always have.
my vcore in bios is like 1.48 vdroop brings it to about 1.456 idle
nb is set at 1.48 so is ht, sb is at 1.5... just remember this is the p5n-d you have to pump the crap out of this board with voltage
Originally Posted by Clinic
I believe the temp where you should be turning your pc off is ~72c. I think that is what the Q6600 is rated for...ish?
alright thanks
At 3.6Ghz load my Q6600 runs at ~46ish across the board I believe.
I <3 watercooling.
WOWW....
