Hi all! So i'm swallowing my pride and now seeking help... I want to get 3.2GHz (400x8) or 3.4GHz (378x9), but I can't seem to stabilize at 3.2GHz on my new ASUS P5Q deluxe (used to get 3.2GHz @ 1.44v on MSI P45 Plat). Right now here are my settings at 3GHz:
JumperFree Configuration Settings:
AI Overclock tuner: Manual
CPU Ratio Setting: 9
FSB Frequency: 333
FSB Strap to North Bridge: 333
PCI-E Frequency: 101
DRAM Frequency: 800Mhz
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 45
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: Enabled
AI Clock Twister: Lighter
AI Transaction Booster: Manual
Common Performance Level [10]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.325
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.50
FSB Termination Voltage: 1.20
DRAM Voltage: AUTO (1.8 default)
NB Voltage: 1.20
NB GTL Reference: AUTO
SB Voltage: 1.10
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
Advance CPU Settings:
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Enabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
Intel® SpeedStep (TM) Tech: Disabled
Settings above are 7 hrs prime95 & 20 runs of LinX (64bit) stable... trouble is passing 3GHz.. want to to stabilize setting for 3.2GHz or 3.4GHz.. I've tried upping voltage up to 1.43v but still no go.. tried upping NB & FSB term to 1.38, still no go.. HALP ME
Btw, temps are somewhat ok as long as cpu vcore doesn't go above 1.5v
