DDR2 is dual channel. FSB is 333, the ram is 2x333=667 under 1:1. FSB is 400 then ram is 2x400=800 under 1:1. So, ddr2 800 to 1066 is fine.
Originally Posted by Makav3li ![]() Is there any advantage in using ddr3 in this situation? Does triple channel mean fsb*3 for memory speed or something along those lines? |
Originally Posted by Makav3li ![]() I have 2gb 667 right now. Each stick is running 333mhz. I believe that makes the ratio 1:1? |
Originally Posted by linskingdom ![]() DDR2 is dual channel. FSB is 333, the ram is 2x333=667 under 1:1. FSB is 400 then ram is 2x400=800 under 1:1. So, ddr2 800 to 1066 is fine. |
Originally Posted by Makav3li ![]() Okay, thank you all for the quick help. It looks like my best option is to go with 2x2gb of ddr2-1066. Browsing this forum shows a lot of you prefer g.skill pi ram. Looking on newegg shows these two kits, does anyone know the difference? The timings and voltage looks the same. http://www.newegg.com/Product/Produc...82E16820231246 http://www.newegg.com/Product/Produc...82E16820231184 Any opinions on one of these pi rams vs dominators? The dominator kit is cheaper and the timings/voltage are the same. http://www.newegg.com/Product/Produc...82E16820145214 |
