im trying to overclock my Q6600 CPU. i couldnt do it before because the bios needed updated so i updated the bios to the latest version and booted up i entered bios and attempted to change the fsb speed. I worked out what to put the fsb to by doing this 1500(fsb) divided by 4(cores)=375(bus) times 8(multiplier) to get 3ghz. I saved the changes and restarted, i entered bios and made sure it was done and sure enough it said 3ghz i then ented windows and started CPU-Z and got this: http://img337.imageshack.us/img337/5919/q6600.png
i repeated the process several times and even changed the bios to an earlier version but still no luck. PLEASE HELP
also i cant get the ram speed to change. i dont have c1e or speed step enabled
this is a repost to try and get more answers
