1 - 8 of 8 Posts
Hey
I have a q6600, its pretty old but yet still beefy when overclocked from stock 2.4 to 3.0 or more, but as soon as I do, the game always twiches, the sound is cut of at time eg: "Hello and wellco.. to the.. bot." actual game way wise, I can't to seem see any problem. The playback of videos also glitches a bit. Could it by because i'm overclocking with EPU-Engine? (2.9ghz oc): I'm wondering this because i wan't to upgrade the graphics card to 660 ti (good idea???) but not sure if this bottle neck at 2.4? thanks.
Anyways specs.
q6600 @ 2.4
asus ptq-e mobo
4gb ddr2 ocz ram
ati 4870 gpu
Not new to Overclock.net
What core voltage do you see in CPU-Z when running Prime95?
What power supply do you have (make and model)?
I still would like to know what PSU you have.
Also, what do you have for CPU cooling?
What do you have for CPU cooling?
Originally Posted by CezarisLT View Post
The cooler is stock, but from an extream CPU so its not really stock. around 60*C on the cpu on games.
60°C is pretty high for only 1.224V. I was going to recommend that you increase the voltage, but I've changed my mind because your temps are already pretty high (for only 1.224V).
1 - 8 of 8 Posts
