Q6600 Temps - is it OK?
788 Views 2 Replies 3 Participants Last post by  eflyguy
firstly i must say that i am not an expert in this hardware overclocking field... though finally decided to overclock my quad to a decent level with a after market cooler (Sunbeamtech CCF)... but not fully sure about the temps on load... so need your suggestions on this... also plz comment on how far i can go with this setup or i need anything else to do....
before using the after market cooler i tried with intel stock hsf... i am putting both the results for a comparison
Abit IP35 Pro (BIOS-14) + Intel Q6600 G0 (VID-1.2875v) + 2x1GB OCZ DDR2 800 + TAGAN 600W
All BIOS settings are @ default except the following ones
Temps are collected from Real Temp 2.70 and ABit uGuru Panel
Default with Intel HSF
External Clock = 2448MHz (272MHz x 9)
Idle CPU Temp (avg of all four core) : 43C
Idle PWM Temp : 38C
Max Load CPU Temp (after min 1hr Everest CPU Stress Test) : 56C
Load PWM Temp : 48C
1st try with Intel HSF
vDIMM = 2.0v
FSB = 334MHz
FSB/DRAM = 5:6
Extrenal Clock = 3006Mhz (stable)
Idle CPU Temp (avg of all four core) : 45C
Idle PWM Temp : 38C
Max Load CPU Temp (after min 1hr Everest CPU Stress Test) : 64C
Load PWM Temp : 48C
1st try with Sunbemtech Core Contact Freezer
vDIMM = 2.0v
FSB = 334MHz
FSB/DRAM = 5:6
External Clock = 3006Mhz (stable)
Idle CPU Temp (avg of all four core) : 36C
Idle PWM Temp : 37C
Max Load CPU Temp (after min 1hr Everest CPU Stress Test) : 51C
Load PWM Temp : 46C
2nd try with Sunbemtech Core Contact Freezer - My current settings
vCore = 1.2975v
vDIMM = 2.0v
FSB = 358MHz
FSB/DRAM = 5:6
External Clock = 3222Mhz (stable)
Idle CPU Temp (avg of all four core) : 37C
Idle PWM Temp : 37C
Max Load CPU Temp (after min 1hr Everest CPU Stress Test) : 53C
Load PWM Temp : 46C
my english is bad.. plz co-operate
thanks in advance
1 - 3 of 3 Posts
1 - 3 of 3 Posts
