I went with a used q6600 when I had the same decision to make. I'm happy with the choice. With the money saved I pieced together a decent wc setup as well.
Definitely try to find a used q6600 with a low vid and a proven overclocker. Well worth it.
My choice is always the Quad with the most cache. I don't even look at the MHarz or such. Q9300 is so not worth it compared to a Q6600... 6MB cache vs 8MB and only 100MHz higher clock on the Q9300... when a Q6600 cost almost the half of what the Q9300...
But it's not about the 9300... still the Q6600 over the Q8300 and the Q9400
Q9400 is the best performer out of them all, but the Q6600 is just a SLIGHT bit behind. It's the best bang for the buck quad right now, and I'd say go with the Q6600 because the difference in price between the two is just too big to justify the performance difference
Q9400 if you aren't going to do extreme overclocking, Q6600 if you are, Q8200 if you need a quad core Intel for the cheapest price. I would go for the Q9400 for the FSB speed and improved architecture.
Well i am going to go quad on this build but what are the advantages of the q9400 over the q6600. Is it just the FSB, higher stock clock and cache or am i missing something here (and core size i think, i have to look).
The core size for a Q6600 is 65nm where the newer quads like the Q9400 is 45nm which will run cooler if you're thinking of overclocking. From what I've read the Q6600 cpu's right now aren't good overclockers.
IMHO I'd suggest you get the Q9400 cpu over the Q6600. Unless you're planning on buying a used Q6600 that's a proven overclocker.
Just my
Just my
Ya thats the plan now. Everything points to the Q9400 but price and it is not has common as the q6600 for overclocking.
Q9400 can oc pretty well given a proper board with high fsb capability along with right ram. You can probably get it to 3.4-3.6 if you spend some time on it. There are some good q6600's on sale here on the forum right now as well and you can probably bargain em to around 160-165shipped.
45nm is the shrink stage of current core microarchitecture. If you have a high fsb such as Gigabyte EP4-UD3P, get Q9400. Otherwise, get a Q6600 especially low vid q6600.
Q9400 is faster clock-for-clock than the Q6600, and cooler besides. I don't know why Intel keeps the price of the Q9400 up - with the die shrink and the smaller cache, by all rights it should be cheaper to make than the Q6600. Micro Center currently has the Q9400 at $180.
Do you already have an LGA775 board? I'm just curious why there's no AMD in your list while you own an AMD. Q6600 is $200 on newegg which is overpriced IMO, they use to be $180.
Overclock.net
