Im not exactly sure if I installed it right, because you can push it up a little and when you do, the temps go up. I tightened the screws as far as they would go. Right now, on stock and full load the temps are 40 40 36 36. Is that ok? Of course, it would help if I could put my side panel on... but the cooler is too wide for that. On idle my temps are about 26 26 22. Is this about normal??
