Q8200 OC on Asus P5Q
5582 Views 5 Replies 5 Participants Last post by  tbates1244
My friend recently built a computer with an Intel Q8200 and an Asus P5Q mobo. He bought the Q8200 since it was $30 cheaper than the Q6600. He wants to overclock his processor and is asking me to help him do it. He just bought a Xigmatek HDT-S1283 CPU fan and it should come in a few days.
I have a Q6600 at 3.6 GHz (400*9) and load temps are around 68* C with a Tuniq Tower. What's the max speed the Q8200s can reach with air? If anyone has overclocked one, what should I set the FSB to? Voltage? Memory divider (He's using 8GB of DDR2-800 RAM)? Also, since the Q8200 is 45nm, what are the max temps?
1 - 6 of 6 Posts
I had a Q8200 before, OCed with my current Asus P5QC, got up to 3.23ghz @ 1.35v. FSB 460 I think, 1:1 ratio memory.
I never owned the q8200 but seeing as it only can do a 7x multiplier, I don't think it will OC any higher than your Q6600, probably lower. Your friend is gona have to have over 400 FSB just to get 2.8Ghz. It will be tough but it should still OC alright.
max temp is 71c
chances are your mobo or ram will limit your overclock
since its a 7x multi
Most boards can do 440fsb and 1.35 volts to make a stable 3ghz outa this. It's a $30 cheaper entry into the quad core market than the 6600 and cause its 45nm it'll run cooler and use less power. I think I'll be including this proc in my next build. I read about the ease this goes thru cpu intensive tasks with that little OC.
Fits the bill just right for me. Cheapest intel quad core with a bit of an OC should make me future proof for a couple years at least.
I understand that 3ghz (420 FSB) will be not hard, or even 3.2Ghz (460 FSB). I was just making note of the fact that at the max native "rated FSB" for that board (400FSB/1600 rated FSB) he will only be at 2.8ghz. The further you go over the max native "rated FSB", the harder it gets to OC. It is a great quad core though, you are correct.
1 - 6 of 6 Posts
