Hey folks,
Back again, i figured out what was wrong with my rig not being able to post the OC settings i had. i didnt give it enough juice...
Well not only was i wrong about that but i cant get my ram (TW3X4G1600C9DHX) to be able to boot at 1600mhz with FSB 400x7.5
Does anyone have the same or very similar components where they got their ram running at 1600mhz timings (9-9-9-24 1.8v or better)? i know that corsair posted a sticky regarding this model not always being able to work with P45's but I was wondering if anyone had figured a workaround.
The best settings ive gotten so far: (one core stopped at Prime95)
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .............: [ Auto ]
CPU Clock Ratio .....................: 7 X
Fine CPU Clock Ratio.................: .5
CPU Frequency .......................: 3.37GHZ (450x7.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...............: [ Enabled ]
CPU Host Frequency (Mhz) ............: 450
PCI Express Frequency (Mhz) .........: 100
C.I.A.2 .............................: [ Disabled ]
Advanced Clock Control [Press Enter]
CPU Clock Drive......................: [ 800 mV ]
PCI Express Clock Drive..............: [ 900mV ]
CPU Clock Skew (ps)..................: [ 0ps ]
MCH Clock Skew (ps)..................: [ 0ps ]
DRAM Performance Control
Performance Enhance..................: [ STANDARD ]
(G)MCH Frequency Latch...............: [ AUTO ]
System Memory Multiplier ............: 3.33D
Memory Frequency (Mhz) ..............: 1500
DRAM Timing Selectable ..............: [ Manual ]
Standard Timing Control
CAS Latency Time.....................: 10
tRCD ................................: 10
tRP'.................................: 10
tRAS.................................: 20
Advanced Timing Control
tRRD.................................: 5
tWTR.................................: 5
tWR..................................: 10
tRFC.................................: 70
tRTP.................................: 5
Command Rate (CMD) ..................: 2
Channel A
Static tRead Value...................: 8
tRD Phase0 Adjustment................: 0 [ AUTO ]
tRD Phase1 Adjustment................: 0 [ AUTO ]
tRD Phase2 Adjustment ...............: 0 [ AUTO ]
tRD Phase3 Adjustment................: 0 [ AUTO ]
Trd2rd(Different Rank)...............: 9 [ AUTO ]
Twr2wr(Different Rank)...............: 7 [ AUTO ]
Twr2rd(Different Rank)...............: 8 [ AUTO ]
Trd2wr(Same/Diff Rank)...............: 8 [ AUTO ]
Channel B
Motherboard Voltage Control
Voltage Type...............
CPU Vcore............................: 1.25625V
CPU Termination….....................: 1.220V
CPU PLL..............................: 1.570V
CPU Referen..........................: 0.760V [ AUTO ]
MCH/ICH
MCH Core.............................: 1.240V
MCH Reference........................: 0.760V [ AUTO ]
MCH/DRAM Ref.........................: 0.750V [ AUTO ]
ICH I/O......................….......: 1.570V
DRAM
DRAM Voltage ........................: 1.800V
DRAM Termination ....................: 0.750V [ AUTO ]
Ch-A DATA VRef.......................: 0.750V [ AUTO ]
Ch-B DATA VRef.......................: 0.750V [ AUTO ]
Ch-A Address VRef....................: 0.750V [ AUTO ]
Ch-B Address VRef....................: 0.750V [ AUTO ]
Advanced Settings
Limit CPUID Max. to 3...............: [ DISABLED ]
No-Execute Memory Protect...........: [ ENABLED ]
Load-Line Calibration...............: [ DISABLED ]
CPU Enhanced Halt (C1E).............: [ DISABLED ]
CPU Thermal Monitor 2(TM2) .........: [ ENABLED ]
CPU EIST Function...................: [ DISABLED ]
Virtualization Technology...........: [ ENABLED ]
settings taken from (http://forums.tweaktown.com/f69/ga-e...so-good-32738/)
Clock Chip Control
Channel A
Channel B
MCH/ICH
DRAM
Advanced Settings
