Q9450 low-ish GFLOPS?
808 Views 4 Replies 3 Participants Last post by  Flying Toilet
Last night I ran the Intel Burn Test on my Q9450.
Stress level high (had 3 gigs free, used 2)
Ran the CPU at 2.66 and 3.2
4 GB DDR2 reapers @ 5-5-5-18, 4-4-4-15 and 4-4-4-12
At 2.66 and 5-5-5-18, the Gflops were ~30. At 3.2 with 4-4-4-15 the Gflops averaged 35.537 after 10 runs. At 4-4-4-12, the Gflops actually dropped to 34.9.
I've searched some other topics and at slightly higher clocks people have been able to reach 50+ gflops with this processor... so what can I do to raise my gflops? If more information is needed I'll be happy to oblige.
1 - 5 of 5 Posts
That's because of Nvidia chipset, for some reason boards with those always get much lower Gflop scores than Intel chipset boards.
This! I would like to see THIS. I reached average 51,x Gflops.
But this was with my [email protected],75GHz and [email protected]
If you want i can do some runs @3,2GHz to compare...but i really doubt that i will get much better results than you. And never 50ish...
BTW i got "intel inside" no nvidia chipset...
3.2 GHz isn't quite enough for 50 Gflops even with a P45 board, mine does bit over 45 Gflops at 3.2. It takes about 3.5 GHz to get over 50 Gflops with my Q9550 system.
Here's the post that got a Q9450 between 49.9 and 50.9 (at 3.6 Ghz):
http://www.overclock.net/intel-cpus/...ml#post7221057
I figured that it'd be difficult to reach 50 with this processor, and I don't wish to get that high, but I would like to get above 35. I managed to get a 35.637 with the memory at 4-3-3-8, but it was unstable. Comparing my results to the Gflops info thread, a Q6600 at 3.2 Ghz nets more gflops... So I believe the nVidia chipset to be at fault here. Thanks for the help guys
1 - 5 of 5 Posts
