Q9450 VS. Q6600 OCed
1425 Views 30 Replies 20 Participants Last post by  Lukeatluke
I'm debating between Q9450 and Q6600, because if I were to buy Q6600 and a water cooling system, the net cost is equivalent to Q9450. I heart on Q6600, with Water cooling, achieving 3.6Ghz OC isn't much problem. I'm not sure how good Q9450 Overclocks though.
Which would be more of an efficient option for me?
1 - 20 of 31 Posts
I wouldnt count on 3.6 with the newer Q6600 even with WC. I'd get a Q9450 and a high-end air cooler and call it a day...
Go with a Q6600 and pray you get a nice VID with WCing.
read:
http://forums.anandtech.com/messagev...readid=2179084
Assuming they're on air cooling, it tops out at around 3.6-4.0~ghz with around a 1.3~vcore.
So you could achieve a same level of overclocking even with Q9550 with Air cooling? (on the frequency level, that is)
with a Q9450 youre guaranteed 3.3-3.6
with a Q9550 youre guaranteed 3.4-3.8
with a NEWER Q6600 youre guaranteed 3.0-3.2
with an older Q6 youre guaranteed 3.2-3.5
all of this considering you have a good aftermarket cooler (tuniq tower, xigmatek, TRUE, vendetta2)
It all really depends on the chip & motherboard.Each on will oc different,you just never know.But with the q9450 you'll need to run your fsb at 450 to achieve 3.6,because of the multi(8x).Where as with the q66 it has a multi of 9x.Either or will do IMO,but as of right now I think I would go with the newer chip.
Holy.... the old ones' for the Q6600 OC guarantee was at 3.5Ghz, if I recall. Why did it drop so significantly all of a sudden?
for the price i'd go with a Q6600.....as long as it's a G0....look in the for sale section....
depends how bad you want water cooling if it was up to me i would rather have a good chip (Q6600) and a nice water cooling system
The newer Q6600's have a higher VID (1.3+) and hit their limit sooner than the older Q6600's.
I'd just get a Q9550, it's virtually the same price as the Q9450 and you'll probably hit 4GHz.
Originally Posted by error10
I'd just get a Q9550, it's virtually the same price as the Q9450.
I forgot about this,go with the q9550.
Yeah with WCing you'll hit 4.0 easy.
But are you sure all the newer G0's are 1.3 VID+? I know most of them are but I'm pretty sure some people strike gold with one < 1.3 VID.
Heh, I've got my 1.3000 VID Q6600 up to 3.6. When are you going to OC yours?
Look at the proof in my SIG..It´s on Air..It´s an 24/7 Setting..Easily could be over 4.0 Ghz..But depend on other components in the Sistem too...
I stick with the 9450, or better for the same price the 9550!!
I tried I got it to 9x @ 3.5 but one core fails after a few minutes of small tests on P95. I did try 8x to try and get a stable 3.6 but my temps kept going above 70°C so I stopped. The most stable clock was @ 3.4 with temps in the mid 60s so I was OK, but I wasn't interested in pushing it for that long just seeing what I am capable of. I got a horrible VID
What's your temps and stuff @ idle and load with your clock, give this guy an idea
get the Q9550 for SURE.. it's only a few dollars more. and cheaper at some places if you get a deal... if you can get an E0 stepping then great. if not then oh well. I've seen almost everyon Q9550 get to 4.0 Ghz on Air.. they are amazing chips for sure.
I'd do that for sure!
my friend just got a Q6600 from TD and it was a 1.2750 VID. I was amazed! either way a Q9xxx is better.
The 1.3250 VID is the worst made for the Q6600 G0. But you should be able to run that 3.4 for 24x7 load. Mid 60s isn't bad. Probably even lower temps if you get a TRUE.
I'd go for the Q9450. It will probably clock higher than the newer Q6600 and has 12MB of cache. It's also 45nm and has SSE4.1 so is cooler and has a newer instruction base.
1 - 20 of 31 Posts
