1 - 4 of 4 Posts
I am trying to OC my Q9650 to 4.050. I have an asus P5E3 Deluxe mobo. Has any one succeded in getting 9*450 with this Mobo.. if so could you list your settings...any suggestions appreciated..Thanks.
Take a look at this article, it may help you, as it seems AT got it, and that is a guide to getting 450FSB on a Quad. 65nm not 45, but the 45's generally clock higher so Good luck bro. Its all in the luck of the chip.
My chip has no problem hitting a FSB of 450 if i leave the memory on auto. My issues come when i try to put my memory to 1800. Im thinking its just my mobo that is stoping me?
I'd downclock the RAM to stock then, and unlink your RAM from your FSB,
You need to say next time you are OCing your RAM as well.
Also, you might need to loosen your timings to something like 9-9-9-24
1 - 4 of 4 Posts
