Hello ocn I'm doing a quad Peltier direct die for 775 ( go on laugh it out...), I am going to use 4x 154watt Peltier at 12volt 8amps for a total of 12volt 32amp, Not for ultra low temps but at least room temp under load, I'm going to make my own aluminium water block just using a drill press and simple tools, yes copper would be better but I'm doing it cheaply, The water block will be 100x100x15mm and the cold side will be 100x100x5mm so its just keeping things simple and yes I know about Peltiers and I know how much heat I have to cool that's why im using 1 240mm rad push pull and 2 120mm rads push pull
that's all I got so far waiting for my bits to turn up!
