1 - 8 of 8 Posts
Old Timer
Which current motherboards will support Kentsfield? What about the upcomming 45nm chips?
Mostly all that support Conroe right now. They are just going to get a BIOS update to support it.
when is amd supposed to come out with their quad core?
<tr>
<div>
Originally Posted by <strong>3000gt</strong>
</div>
<div style="font-style:italic">when is amd supposed to come out with their quad core?</div>
</td>
</tr>
</table>
</div>Midish 2007?
<tr>
<div>
Originally Posted by <strong>mycomputersucks</strong>
</div>
<div style="font-style:italic">Mostly all that support Conroe right now. They are just going to get a BIOS update to support it.</div>
</td>
</tr>
</table>
</div>Not true with 90% of the boards. For example, the DS3 needs a new PCB rev, because it won't support the Kentsfield. The DS3 now might be supported by Kentsfield, they said by mid October. As for 45nm, that's a year off, and I'm sure you will have upgraded your board by then.
<tr>
<div>
Originally Posted by <strong>wowza</strong>
</div>
<div style="font-style:italic">Not true with 90% of the boards. For example, the DS3 needs a new PCB rev, because it won't support the Kentsfield. The DS3 now might be supported by Kentsfield, they said by mid October. As for 45nm, that's a year off, and I'm sure you will have upgraded your board by then.</div>
</td>
</tr>
</table>
</div>Hmmmm..well the DS3 already supports the Kentsfield actually. I just got a BIOS update that let me do so.<br />
<br />
Proof is here.<br />
<a href="http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ClassValue=Motherboard&ProductID=2314&ProductName=GA-965P-DS3" target="_blank">http://www.gigabyte.com.tw/Support/M...me=GA-965P-DS3</a><br />
V. F7 Supports kentsfield.
<a href="http://www.anandtech.com/mb/showdoc.aspx?i=2848&p=1" target="_blank">http://www.anandtech.com/mb/showdoc.aspx?i=2848&p=1</a>
all the gigabyte boards should supposrt it with a bios update , but only the dsq6 will support it out of the box , <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
1 - 8 of 8 Posts
