They're geared for commercial apps, not gaming, and are focused towards OpenGL.
I've heard of people flashing the BIOS to turn them into their GeForce counterpart, and then you can use the GeForce drivers and get the same performance, but I've never done it/confirmed it and not sure if it would work the other way around. So make sure you look into this specifically.
And yes, the QuadroFX series seriously does better with Solidworks. Was running Solidworks on my 8800 Ultra and it lagged a bit. A Quadro from one generation earlier handled it no problem. Drivers/BIOS make the difference.
