1 - 4 of 4 Posts
I'm Having Trouble Applying Anti Liasing In Quake 4. Everytime I Set It It Says I Have To Restart Quake For It To Take Effect But When I Do It Always Goes Back To Default (off). My Video Card Has Been Set To Application Preference In Control Panel.
Was Wondering If Someone Can Help Me Please
im not sure but miby your card does not support the anti Liasing im not sure about ati thou . does it allow you to change your setting at all or dose it tell you to restart ?
Did you play around with your Quake 4 .cfg folder? Maybe you were trying to tweak some settings. That folder should not be locked or view only.
just dont fix it on quake 4
go on your video card drivers and fix it there. then apply the change and get back on quake...
hope it helped you because its the best way to do it
1 - 4 of 4 Posts
