Quality Modular PSU
534 12
So I'm supposed to buy a PSU for another computer, but instead I might upgrade mine and toss my old one in there.
I bought this before I kinda didn't know much about computers and was like omg 850watt!!
So, my budget is 150$ newegg is a must, and I want a quality one, I know that Seasonic makes Corsair PSUs and I know they're good, but how about Silverstone?
This one specifically http://www.newegg.com/Product/Produc...82E16817256045
Any input is much appreciated.
Thanks.
Bought the Corsair 620 modular and whooh - Very nice PSU!
1 - 13 of 13 Posts
Originally Posted by TFL Replica
A big issue with silverstone PSUs is the lack of any sort of power switch.
I don't really see that as a con, how about quality? Are they good?
Where's duckie when you need him? quack quack
Originally Posted by Maddog7771
Yeah i would just go with the corasir 600w modular. Never go cheap on your power supply you will regret it
Who's going cheap? 150$ is a nice budget >_>. I'm asking if this is a good brand.
Discussion Starter · #6 ·
Originally Posted by linskingdom View Post
ST series is bit different than DA and OP series but should be fine. GXT260 is a 182w GPU and 8600GT draws 45w so it has plenty power. The Corsair 620hx should be fine. Also, take a look at the DA700/750.
I'm sure they'll have pleanty of power, it's just I'm unsure which one. I'm leaning towards the Corsair one though :<
Discussion Starter · #12 ·
Originally Posted by MCBrown.CA View Post
Corsair HX520 or HX620.
I own one of each and I've been nothing but satisfied with them!
Meh, I'll pull the trigger on the 620. Thanks, reps +
edit: Just bought it
1 - 13 of 13 Posts
