Hi everyone
I have a bit of a specific question
I am planning to build a new mini-itx gaming computer
and I thinking of using the Lian-Li-TU200 case
what I would like to do is, remove the hdd cage and fit a radiator with a push & pull fan setup
however... (and here is my question) ... would a push& pull setup with a radiator interfere with a long Videocard?
From the pictures i have seen it would seem it would if I used a 140mm rad... but am wondering if i used a fan adapter and
used a 120mm rad it would not be the case...
Or should I just get something completely different instead?
