1 - 3 of 3 Posts
ok so i have a pair of sennheiser hd 598 and i been doing a bit of research and looking at amps and dac's under 200 and what im wondering is
so far from my research im leaning towards the audioengine d1 dac/amp and was wondering if this is the best option i did look into the magni/modi but i need a usb in for music and also for gaming a optical in and you only get one or the other with the magni/modi so any feedback would be helpfull thank you very much
Audioengine D1 should be fine. Never sacrifice functionality that you'd actually use and settle for something that doesn't have the inputs or whatever else you need.
1 - 3 of 3 Posts
