1 - 2 of 2 Posts
Im about to build my first loop and I was wondering if some of the nano fluids can go longer than say DI-water (De-Ionized water) in terms of how often they will need drained, flushed, and refilled. I read online that you should flush your loop about every 6-12 months if using DI-water but you only need to do it every 36-48 months if you are using something like a nano fluid. I originally planned to use DI-water before I read this as I not only wanted a clear liquid in this particular loop but I can also get DI-water from work for free (we have a dept that has a machine that makes it) but after reading this (if its true) I might consider a clear nano fluid if they make one just so I dont have to flush it as often. What do you guys think?
For now, check out this, here
1 - 2 of 2 Posts
