Hello, I'm trying to use my GPU (5850) to decode h264 .mkv 720p and 1080p files. I use MPC-HC, and when I run the program I use EVR Sync (Should I use custom pres?). When I play the file, at the bottom of MPC it says DXVA, and I see Haali Media Splitter and AC3 Filter running as well. I use AC3 filter for my sound over ffdshow.
When I go to filters in MPC while playing a video it shows: Direct Sound device, sync renderer, audio switcher, mpc video decoder, and ac3 filter.
GPU shows around 1-2% uses, somtimes hitting as high as 12% for a brief moment, generally every minute or so it will spike, but mostly is 1-3%
Internal Filter section of MPC-HC shows all filters are checked, for h264 audio[DXVA] but what is not checked is Matroska. It unchecks that when I install, it was my impression that you leave it unchecked to have the filter used that you installed over the default one that comes with MPC. I also thought maybe it needed to be unchecked for DXVA. I've read a few guides real quick and they suggest checking the Matroska box in Internal Filters.
My question is, is that because they don't use any other filters? I believe when I installed mine, it used either FFDshow or Divx's h264 filter. But when I installed MPC-HC, it gave an option at the end with two check boxes about enabling the internal MPC DXVA filter, which I did. So, which settings do I want for DXVA, and should I reinstall MPC-HC and not use the internal DXVA filter and use the ones that installed with my codecs? Do I check the internal filter box for Matroska or is that for when you do not have the filter already installed from another source?
I hope I listed everything needed, I feel generally secure in my understandings of decoders, filters, containers and all that, but it still seems confusing in that there appears to be many different combinations of decoders/filters and such to be used, its hard to believe I'm using the exact right combination that best suites image quality and efficiency.
Thanks for all the help, its very much appreciated!
