There is no need to format or recreate the RAID 0.
When you re-install windows, windows 7 will, if you choose to quick format the partition.
Windows 7 has all the drivers you need for the RAID device
Once windows is installing, it will instal;l the correct driver for you. You don't need to change anything. You can if needed, install the Intel Matrix Software for monitoring but it is not needed for the running of windows.
