Question about GPU-Z temp readings
310 1
Should I be concerned with the Shadercore Temp? it always seems to be higher than everything else, and is always in the 70-80 range, and I have seen upwards of 85C.
I have the fan speed set at 75% and it sounds like its about to take off.
1 - 2 of 2 Posts
You should be fine as long as you do not exceed 100*C on your GPU.
If you want, you can buy 2 Zalman VF900's for the HD4850x2. And those should lower your temps by a great deal.
1 - 2 of 2 Posts
