1 - 8 of 8 Posts
Ok, I notices a lot of them on laptops are like 1.6 or 1.8 upto 2.0Ghz. Now my question is this. How dose a laptop or computer use this speed?
Dose it have a 1.6hz+1.6Ghz = 3.2Ghz?
or how dose this work?
Retired
Dual core laptops are the same as dual core desktops. It has two cores, each running at the same speed. Each core can work on different processes at the same time. Both cores cannot work on the same process (until reverse hyperthreading...). 2.0+2.0=2.0.
Discussion Starter #4
I c, cool thanks for the info. So, one more question. Because application now this days like games etc.. saying that it needs a 1.5Ghz or higher. Do you guys think I should go with the 1.6ghz Core 2 Duo or 2.0Ghz?
2>1.6 but if its huge in money difference then dont worry about it I suppose
Those requirements are probably for a 1.5ghz Netburst CPU (e.g. Pentium4).
A 1.6ghz Core 2 Duo is equivalent to ~3.2ghz Pentium 4
and 2.0ghz Core 2 Duo is ~4.0ghz Pentium 4.
All calculations found using CPU Speed Converter v2.0.
1 - 8 of 8 Posts
