Question about mosfet water block for 780i reference board.
333 Views 6 Replies 4 Participants Last post by  supaspoon
it comes with rubbery pads, sticky on other side and kinda rough on the other side. My question is does the sticky side goes to motherboard mosfet? Instruction came with it is not helpfull at all.
Thanks in advance.
1 - 7 of 7 Posts
did they come with a backplate?
no just that rubber pads.
I'd put the sticky part on the mosfets.
ty
I've got the same block (didn't use it though, restriction is rediculous). I guess it'd make more sense to put the rough side to the board, as the smooth side will make better contact w/ the block surface. Aside from that just make sure to peel off the plastic films.
1 - 7 of 7 Posts
