Question about overclocking
288 Views 2 Replies 3 Participants Last post by  DuckieHo
Does the memory speed on the GPU affect how high you can go with the core?
For example if I wan't to leave GPU mem to stock untill I find a stable GPU core speed, the low mem speed won't cause artifacts (only bottleneck)?
1 - 3 of 3 Posts
What card do you have and we can probably help you a bit more (is it your sig comp). But theoretically, no, the memory isn't related to the core clock.
Thanks
Comps
They should be pretty much independent.
1 - 3 of 3 Posts
