1 - 2 of 2 Posts
The last time I got myself in a fix and I had to reinstall windows it would not work correctly so I called Tech support and they told me it was because i had changed the graphics card and taken the modem out. Sure enough I put the old hardware in and the install worked properly. Is there anyway around this?
save everything and reformat while installing windows so you start clean.
1 - 2 of 2 Posts
