1 - 1 of 1 Posts
So i was able to get a oc of 4.4 ghz at 1.30 v core stable all i did was change the vcore and the ratio ,is there anything in the bios i should turn off and disable?i remember back for the older sockets you would disable stuff like speed step etc
also i remember back then you could disable something to see your new clock in the system info what is it now?i do see the 4.4 under cpu z but want to see it there as well
1 - 1 of 1 Posts
