Question about Socket A mobo?
279 Views 4 Replies 3 Participants Last post by  simfreak47
I just got this for free (with a XP 2400+)
http://pcchipsusa.com/prod-m810dlu-75.asp
and 1 512mb stick of DDR. It says the max it supports is 1GB total is this true? I was planning on buying a 1GB stick for 1.5GB total, but not if it wont work...
Also, will it overclock?
1 - 5 of 5 Posts
1.5 is useless for that unless you can utilize if for the igp. those old chips can barely overclock about 100 or 200 mhz.
I've had a few mobo's work with 1.5GB When they said they would work with a max of 1GB. That was on a P4 HP Mobo though, so you'll have to take a chance there
Hmmm i wish i had some ddr1 laying around so I could try it. Useless? Even in XP 1.5GB is faster than 1GB. And a 1gb stick barely costs any more than a 512 so if it will work id rather get the 1GB.
Yeah, I agree that 1.5GB > 1GB. Makes a lot of difference.
Good luck with the search!
1 - 5 of 5 Posts
