1 - 20 of 40 Posts
Hello,
I just installed a SSD, 640g black, and win7. I put OS on the SSD but my computer isnt showing the 640 black, why is that.
I am really impressed with the SSD.
Go to Disk Management. Format and label your HDD.
Originally Posted by Darkshadow74 View Post
also how do you turn on Trim with Win7
It's already enabled since you have a SSD.
Discussion Starter #7
do i want to initialize disk one as MBR or the other?
Your SSD should already have a MBR.
Discussion Starter #9
And the suddering when scrolling on internet explore is that normal?
Discussion Starter #13
Ok i am in disk management, i see my DvD drive. my SSD, and in the bottom i see the 640, how do i format it from there?
Right click.
Discussion Starter #16
found it, never mind, should i just set it as E drive?
Discussion Starter #18
Originally Posted by Slider46 View Post
Disable pagefile on your SSD and enable the system to manage the pagefile once your 640 is setup.
How do i go about doing this? I have the 640 set up as E drive.
Edit: ok it just stop on its own. dont know why but it did,
Some say disable it, and some say "I didn't buy SSD's to not use them!"
I disable Prefetch and windows search! And also move the IE Temp file to a HDD
Discussion Starter #20
Also should i be defraging my SSD like I do my HD? or is that what trims all about. And do i need to do anything other then just have a SSD in, with trim?
1 - 20 of 40 Posts
